after I configured the default domain policy following the instructions of Microsoft, I can't get any PC on lansweeper's dashboard.
What I did was create an script called inventario.vbs, setup it as user logon script, and then put it on the path you can say on the image2 (togheter with LSclient.exe)
But I have several doubts:
1. In which GUID should I put the .vbs file. Because under the path "policies" I have several ones, and I actually are using the GUID that show me the window (I´m configuring it using Terminal Server)??? (you can see the several GUID below, in the last image)
2. Is it necesary to put also LSClient.exe in the same folder as the vbs file?? I also have LSCLient in the netlogon folder of my DC.
So, what I'm doing wrong?
Thank you very much.
