Having installed lansweeper on a SBS2003 network, I couldn't reach any of the clients.
I have read through these forums (and others) and have checked the following using the connection tester.
If I stop the windows firewall service, I can connect fine, with windows firewall active I get the following errors:
Remote WMI test
The RPC server is unavailable. (Exception from HRESULT: 0x800706BA)
I am able to connect to the client registry from the server using regedit > remote registry
I am able to connect to \\clientname\c$ from the server
nslookup resolves name>ip and IP>name
I have disabled the RPC filter in ISA and created a rule with strict RPC compliance disabled as per the post http://www.lansweeper.com/forum/yaf_postst307_WMI-RCP-errorsproblems--Solved-for-me.aspx
I followed the instructions at http://www.lansweeper.com/kb/notfound.aspx and enabled remote admin in GP but this made no difference so I tried to enable it using the command netsh firewall set service type = remoteadmin mode = enable
It responds with OK but when I check the state using netsh firewall show state i get the following response
Firewall status:
Profile = Domain
Operational mode = Enable
Exception mode = Enable
Multicast/broadcast response mode = Enable
Notification mode = Enable
Group policy version = Windows Firewall
Remote admin mode = Disable
Ports currently open on all network interfaces:
Port Protocol Version Program
26675 TCP IPv4 (null)
1140 TCP IPv4 C:\Program Files\Lexmark 3500-4500 Series\lxdimon.exe
135 TCP IPv4 C:\WINDOWS\system32\inetsrv\inetinfo.exe
137 UDP IPv4 (null)
139 TCP IPv4 (null)
138 UDP IPv4 (null)
38191 TCP IPv4 C:\Program Files\Lexmark 3500-4500 Series\lxdiamon.exe
3389 TCP IPv4 (null)
445 TCP IPv4 (null)
19226 UDP IPv4 C:\Program Files\Panda Software\Panda Administrator 3\Pav_Agent\Pagent.exe
19226 TCP IPv4 C:\Program Files\Panda Software\Panda Administrator 3\Pav_Agent\Pagent.exe
6004 UDP IPv4 C:\Program Files\Microsoft Office\Office12\OUTLOOK.EXE
990 TCP IPv4 C:\Program Files\Microsoft ActiveSync\rapimgr.exe
whatever I do it seems to report that remote admin mode is disabled.
I decided to check the registry, in [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile\RemoteAdminSettings the dword Enabled is set to 1 (is this enabled)
does anyone have any ideas?
