Matt_Sullivan
I use Group Policy to run the LSclient.exe every time someone logs into the domain, and it's always worked fine. Since upgrading yesterday my script now says "Connecting.... Failed" when logging on.
The script is very simple:
start %logonserver%\netlogon\lsclient.exe my-LANsweeper-Server
The lsclient.exe has been upgraded correctly, and everything else looks fine. Any one else having this problem?
@rmousigian : is this a reply to the same problem?
rmousigian
I specified the domain I wanted scanned. I don't see where I can attach a file so here is the entire error log.txt:
3/11/2009 8:38:13 AM: Database connection successful, starting up service
3/11/2009 10:49:22 AM: Stopping service
3/11/2009 10:49:23 AM: Database connection successful, starting up service
Matt_Sullivan
Answer is here:
http://www.lansweeper.com/forum/yaf_postst1260_Fix-Operator--is-not-defined-for-type-DBNull-and-type-Boolean.aspx
Matt_Sullivan
Should the server be listening on 9524? The config file say this, and the Lansweeper service is running, but I do not have a service listening on 9524.
