rendi
Dear Admin,
how to remote control without the user initiating the Remote Control session must have administrative privileges on the target machine ?
is there another way ?
rendi
Ok thanks for your information, i can try for your solution.
You can try using runas.exe to run an action as a different user, as discussed here: http://www.lansweeper.com/forum/yaf_postst4665_Admin-needed-to-make-Actions-run.aspx
