abolus
hi , i try using remote control in the lansweeper but it does not give any notification to the (user)PC that i am trying to control the PC, so that the user have the choice to accept the remote connection or not. is it possible to set the setting to notify the user for remote control connection?
thanks
This is not possible by default.
But if you search the forum, some user has created an extension for this.
