tdecenso
I was wondering if you guys where aware that the Remote Uninstall Utility has issues uninstalling MS Visio 2007 and MS Project 2007. Is there any workaround?
It just sits there for ever.
Thank you,
Tim
The uninstall utility using the commands available in the registry.
Not all installations can be run hidden or need extra parameters (depending on the vendor)
