wierzbowski
Hi
Thanks for adding the IP location feature to the Lansweeper Product.
I am about to import 3000 small ip ranges (6 IPs) into the tsysIPLocations table.
I dont want to add this many rows to the console so i'd like to know if its advisable to remove the IP Range Location Overview portlet from the web console and whether it will cause other issues.
The code seems to be at the bottom of state.aspx
Thanks in Advance
Rob.
wierzbowski
OK, I've done it and its gone.
Thanks.
Rob
If you know what you are doing you can change the state.aspx page.
