jasonbrink
I'm trying to restrict our web console to just IT employees. I followed the article on the Knowledgebase and I'm getting the below error.
Server Error in '/' Application.
Configuration Error
Description: An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately.
Parser Error Message: The 'compilation' start tag on line 15 does not match the end tag of 'system.web'. Line 16, position 4.
Source Error:
Line 14: </authorization>
Line 15: <compilation debug="false" strict="false" explicit="true">
Line 16: </system.web>
Line 17: </configuration>
6 REPLIES 6
jasonbrink
Fair enough. Thanks for the help. When 4.0 is out of beta, I will switch over to IIS.
The website hasn't been updated yet because version 4.0 is not final but integrated authentication is only supported with IIS.
jasonbrink
I'm using the internal lansweeper webserver, not IIS. Does that make sense? I'm guessing I still need to enable integrated authentication, but not sure where since I'm not using IIS.
Could you post the whole config file please.
Did you enable integrated authentication in IIS?
jasonbrink
I was missing just that one slash, thanks.
I was able to get it to say "Access Denied" now, but I can't figure out how to make the roles work. I added the a group that I below to, and I'm still getting access denied.
<allow roles="ALC\ALC-IT" />
ALC is our NetBIOS domain name, and ALC-IT is a security group every IT employee belongs to. I'm getting Access is denied.
Any help is appreciated.
Change this line:
<compilation debug="false" strict="false" explicit="true"/>
