‎01-12-2011 04:03 PM
We have a Window 2003 AD domain that only (at present) has XP SP3 clients. Some of our laptops are used by folks that work from home and these connect to the network using VPN tunnel to our ISA Server 2006 'firewall'. None of these are scanned unless the physically connect to the network.
I have implemented via Group Policy Windows Firewall settings and ensured that RPC and WMI kb's have been followed.
Is there a way to scan endpoints through a VPN tunnel?
Tony
‎01-18-2011 03:35 PM
‎01-18-2011 03:11 PM
Am now getting just RPC server is unavailable 0x800706BA (10.1.1.118)
‎01-18-2011 03:08 PM
Can you check the isa server log if it's dropping traffic between the lansweeper server and the vpn client.
‎01-18-2011 02:26 PM
Do you see any rpc errors (or other errors)
‎01-18-2011 02:45 PM
Lansweeper wrote:
What is the waittime for software in your configuration?
2 days, although the previous scan was done on the 7th January
Yes:
The RPC server is unavailable 0x800706BA(REL2651.domain.org.uk,REL2651,10.1.1.118)
Cannot connect to DCOM port 135:Firewalled? (REL2651)
As per my original post, I have worked through all the KB's around this and it only appears about 3 minutes after I run LSClient - I've even turned Windows firewall off
‎01-18-2011 02:48 PM
Is 10.1.1.118 the correct IP address of the client?
Do you see a different IP address if you use the lsclient /scanonip option?
‎01-18-2011 02:52 PM
Sorry, I forgot to mention that 10.1.1.118 is the correct IP address and is the same regardless whether I use /scanonip or not
Cheers
‎01-18-2011 02:23 PM
I now have scanning through the VPN Tunnel using LSClient (with and without the scanonip switch), unfortunately it does not seem to be updating the software tab (which at the moment is my main concern) although it does update the last logon as shown in Config > User info. Is this by design or do I need to use something else?
Cheers
Tony
‎01-12-2011 04:16 PM
It's possible that your dns server is not updated and lansweeper tries to scan the internal IP address of the client.
You can try lsclient with the "/scanonip" option on the vpn computers.
