johan
How is the scanning done?
Where is the trigger to do a scanning apart from the db table where you set
the days or the 0?
If set to 0 for an item when will that item be scanned, apart from the logon?
johan
As alternative via the sheduler send the lsclient...
Ha de Johan,
If you set the day to zero, that item will be scanned each time the user logs on.
You can no trigger the scanning, scanning is only performed at logon.
Logons are added to a scanning queue.
