dthebike
I cannot get the client to connect.
Running lswinap on server, which connects to SQL OK (how can I tell? it doesn't give errors though).
User lsscanner is Domain Admin and can access SQL (logged onto Query manager and can see tables OK)
When I run lsclient it gives "Connecting to <serverIP>: failed."
Any ideas what to check......
Donald
ddion
Your error seem to be with the LSCLIENT. syntax is: LSCLIENT.EXE servername
or LSCLIENT.EXE serverip
Also, if there is a firewall on the server or between the server and client, you need to have the port: 9524 open
Dany Dion
