jperry
I smashed this together pretty quickly, but thought I'd share.
As part of SCCM OSD I have a vbs script that writes environment variables to the registry.
Then I collect those with LS.
Add scanning HKLM registry entries to LS
SOFTWARE\_IT\SCCM\OSD
'Installed Date', 'TaskSequenceName', 'AdvertisementID', 'Organization', 'TaskSequence ID', 'TSVersion', 'SMSClientGUID', 'OSDComputerName'
Add scanning file to LS
C:\windows\ccm\ccmexec.exe
The vbs script is as follows.
Called before the application installs with %WINDIR%\system32\cmd.exe /c %WINDIR%\system32\cscript.exe AddImagingDatesToRegistry.vbs
On error resume next
dim osd
dim strkeypath
set env = CreateObject("Microsoft.SMS.TSEnvironment")
const HKEY_LOCAL_MACHINE = &H80000002
'variables
TaskSequenceName = env("_SMSTSPackageName")
AdvertisementID = env("_SMSTSAdvertID")
Organization = env("_SMSTSOrgName")
TaskSequenceID = env("_SMSTSPackageID")
Packagename = env("_SMSTSPackageName")
MediaType = env("_SMSTSMediaType")
TSVersion = env("TSVersion")
SMSClientGUID = env("_SMSTSClientGUID")
OSDComputerName = env("OSDComputerName")
Set oReg=GetObject("winmgmts:{impersonationLevel=impersonate}!\\.\root\default:StdRegProv")
'----------- Write to registry ---------------
strKeyPath = "SOFTWARE\_IT\SCCM\OSD"
oReg.CreateKey HKEY_LOCAL_MACHINE,strKeyPath
strValueName ="Installed Date"
strValue = formatdatetime(date,2) & " " & formatdatetime(time,3)
oReg.SetStringValue HKEY_LOCAL_MACHINE,strKeyPath,strValueName,strValue
strValueName = "TaskSequenceName"
strvalue = TaskSequenceName
oReg.SetStringValue HKEY_LOCAL_MACHINE,strKeyPath,strValueName,TaskSequenceName
strValueName = "AdvertisementID"
strvalue = AdvertisementID
oReg.SetStringValue HKEY_LOCAL_MACHINE,strKeyPath,strValueName,AdvertisementID
strValueName = "Organization"
oReg.SetStringValue HKEY_LOCAL_MACHINE,strKeyPath,strValueName,Organization
strValueName = "TaskSequence ID"
oReg.SetStringValue HKEY_LOCAL_MACHINE,strKeyPath,strValueName,TaskSequenceID
strValueName = "TSVersion"
oReg.SetStringValue HKEY_LOCAL_MACHINE,strKeyPath,strValueName,TSVersion
strValueName = "SMSClientGUID"
oReg.SetStringValue HKEY_LOCAL_MACHINE,strKeyPath,strValueName,SMSClientGUID
strValueName = "OSDComputerName"
oReg.SetStringValue HKEY_LOCAL_MACHINE,strKeyPath,strValueName,OSDComputerName
The report
tblAssets.Firstseen,
SQLSCCMOSD."Installed Date" AS [OSD Installed Date],
SQLSCCMOSD.TaskSequenceName AS [OSD TaskSequenceName],
SQLSCCMOSD.AdvertisementID AS [OSD AdvertisementID],
SQLSCCMOSD.Organization AS [OSD Organization],
SQLSCCMOSD."TaskSequence ID" AS [OSD TaskSequence ID],
SQLSCCMOSD.TSVersion AS [OSD TSVersion],
SQLSCCMOSD.SMSClientGUID AS [OSD SMSClientGUID],
SQLSCCMOSD.OSDComputerName AS [OSDComputerName],
tblAssetCustom.Location,
tblAssets.Lastseen,
tblFileVersions.FileVersion As CCMEXEC,
Convert(Decimal(7,2),tblAssets.Uptime / 60 / 60 / 24) As [Days up],
Left(tblADComputers.OU, CharIndex(',', tblADComputers.OU) - 1) As OU,
tblADusers.Displayname,
tblADusers.Username,
tblADusers.Userdomain,
tblAssetCustom.Model,
tblComputersystem.SystemType,
tblOperatingsystem.Version As [OS Version],
tblOperatingsystem.Caption As [OS Name],
tsysIPLocations.IPLocation,
tblAssets.IPAddress,
tblADComputers.OU As [OU Full],
tblAssets.Description As [LS Description],
tblADComputers.Description As [AD Description]
From tblAssets
Left Outer Join tblADusers On tblAssets.Username = tblADusers.Username
Left Outer Join tblAssetCustom On tblAssets.AssetID = tblAssetCustom.AssetID
Left Outer Join tblState On tblAssetCustom.State = tblState.State
Left Outer Join tsysAssetTypes On tsysAssetTypes.AssetType =
tblAssets.Assettype
Left Outer Join tblADComputers On tblAssets.AssetID = tblADComputers.AssetID
Left Outer Join tblOperatingsystem On
tblAssets.AssetID = tblOperatingsystem.AssetID
Left Outer Join tsysIPLocations On tsysIPLocations.LocationID =
tblAssets.LocationID
Left Outer Join tblComputersystem On
tblAssets.AssetID = tblComputersystem.AssetID
Left Outer Join tblFileVersions On tblAssets.AssetID = tblFileVersions.AssetID
And tblFileVersions.FilePathfull Like '%ccmexec.exe'
Left Outer Join (
Select
AssetID,
Max("Installed Date") AS [Installed Date],
MAX("TaskSequenceName") AS [TaskSequenceName],
MAX("AdvertisementID") AS [AdvertisementID],
MAX("Organization") AS [Organization],
MAX("TaskSequence ID") AS [TaskSequence ID],
MAX("TSVersion") AS [TSVersion],
MAX("SMSClientGUID") AS [SMSClientGUID],
MAX("OSDComputerName") AS [OSDComputerName]
from
(SELECT TOP (1000) [RegistryID]
,[AssetID]
,[Regkey]
,[Valuename]
,[Value]
,[Lastchanged]
FROM [lansweeperdb].[dbo].[tblRegistry]
Where tblRegistry.Regkey = 'HKEY_LOCAL_MACHINE\SOFTWARE\_IT\SCCM\OSD'
) AS SourceTable
PIVOT
max(value)
For Valuename in ([Installed Date], [TaskSequenceName], [AdvertisementID], [Organization], [TaskSequence ID], [TSVersion], [SMSClientGUID], [OSDComputerName])
) AS RegTable
Group By
AssetID
) AS SQLSCCMOSD ON SQLSCCMOSD.AssetID = tblAssets.AssetID
Where
tblComputersystem.Domainrole < 2 And tblState.Statename Like 'Active%'
Order By
tblAssets.Firstseen Desc,
SQLSCCMOSD.Organization Desc,
SQLSCCMOSD.TaskSequenceName Desc,
SQLSCCMOSD.AdvertisementID Desc,
SQLSCCMOSD."Installed Date" Desc,
tblAssets.Lastseen Desc,
tblAssets.AssetName
0 REPLIES 0
