12345678qqqq
i hope that question does not appear at all...
everytime i start the server, ther service lansweeperpro seems to run and everything looks fine, but when the client try to connect, it fails, after restarting the service on the server everything i ok.....
is there a solution for that....
in my opinion it has something to to with the order the services start, and that the lansweeperpro service starts berfore the sql-service ??
is that a solution to make some depencies on the services????
or do you have already a solution for that....
it is not that big problem, but it is a little bit awful...
Version 3.1 solves this problem
12345678qqqq
no i am using 3.0 ....
do you think it is better to update lansweeper now (because it is beta as i now?!)
or to do the depencies on the services....
filipe_teixeira
in lansweeper i got the same problem.
because the lansweeper service started before the sql service.
in the 3.1 version i don't have that problem anymore.
trwagner1
In my first test with version 3.0 I set this up on my laptop. On my second test with this, I've got this set up on a virtual machine. Both would be quite slow. I set up a service dependency. My eventual deployment will probably be to a SQL farm with the service running on a common task server.
Anyway, one thing you can try is setting up the Lansweeper with a service dependency on the SQL service. You can find that link here:
http://support.microsoft.com/kb/193888
Are you using Lansweeper3.1?
The lansweeper31 service waits for the sql service and tries 3 times with a pause from 30 seconds before dying.
