soucyinter
I have created this SQL Report this morning and I have double entries. I guess it has something to do with the fact I use TblADUsers and TblComputers but I ain't a 100% sure about it... I know there's a trick with Inner Join or Left join....
I'd say that 85% to 95% of the entries are in double, others are not.
Here it is :
________________
Select Top 1000000 tblerrors.CFGname, tblComputers.Lastseen, tblComputers.FQDN,
tblComputers.Computer, tblComputers.LastknownIP, tblADusers.OU
From tblComputers
Inner Join
tblerrors On tblComputers.Computername = tblerrors.Computername
Inner Join
tblADComputers On tblComputers.Computername = tblADComputers.Computername
Inner Join
tblADusers On tblComputers.Username = tblADusers.Username
Where tblerrors.CFGname Like 'WMI%' And tblADusers.OU Like '%SPI%'
_________________
TblComputers and tblADUsers must be linked on both the Username and Userdomain fields. Please try the modified report below.
From tblComputers Inner Join
tblerrors On tblComputers.Computername = tblerrors.Computername Inner Join
tblADusers On tblComputers.Username = tblADusers.Username And
tblADusers.Userdomain = tblComputers.Userdomain
soucyinter
After trying your query, it is not working. Still all the duplicated data.
I will use the "distinct" function then.
Thank you for supporting us this fast!
You guys have a great support team.
soucyinter
I will try your query and see what it does.
I have modified the one I created this morning, I found out that by using "distinct", it clears my double entries (because all rows have the same exact information). Then I cleaned up a few lines of code.
Here it is :
Select Distinct Top 1000000 tblerrors.CFGname, tblComputers.Lastseen,
tblComputers.FQDN, tblComputers.Computer, tblComputers.LastknownIP,
tblADusers.OU
