johnwomble
I get the following SQL error on the homepage where I should get the IP location overview. Is there any sql/script I can run to fix this?
System.Data.SqlClient.SqlException: Could not find stored procedure 'dbo.web40getiplocationtotal'.
This error happens when the website is updated but not the database.
Solution: run the upgrade and update to the latest version.
