‎01-30-2008 03:52 PM
System.Data.SqlClient.SqlException: Invalid column name 'computer'.
at DreamweaverCtrls.DataSet.DoInit() System.Data.SqlClient.SqlException: Invalid column name 'computer'.
at DreamweaverCtrls.DataSet.DoInit()System.Exception: The DefaultView was requested but no tables yet exist.
at DreamweaverCtrls.DataSet.get_DefaultView()System.Data.SqlClient.SqlException: Invalid column name 'computer'.
‎02-01-2008 09:00 PM
‎02-01-2008 08:51 PM
Startup lsmanage.exe
go to database scripts.
paste the following and execute sql script
alter view dbo.web30repNotLatestSPwinXP
as
SELECT dbo.tblComputers.Computername AS Computer, dbo.tblOperatingsystem.Description, dbo.tblComputers.Lastseen
FROM dbo.tblOperatingsystem INNER JOIN
dbo.tblComputers ON dbo.tblOperatingsystem.Computername = dbo.tblComputers.Computername
WHERE (dbo.tblOperatingsystem.Version = '5.1.2600') AND (dbo.tblOperatingsystem.ServicePackMajorVersion <> '2')
‎02-01-2008 08:37 PM
‎02-01-2008 08:08 PM
‎02-01-2008 08:06 PM
For all reports that are visible on the "digital dashboard" the fieldname "computer" should be defined. (by default it's named "computername")
solution:
change query
SELECT dbo.tblComputers.Computername, dbo.tblOperatingsystem.Description, dbo.tblComputers.Lastseen
to
‎02-01-2008 07:56 PM
‎02-01-2008 07:49 PM
‎02-01-2008 07:44 PM
‎02-01-2008 07:38 PM
