josteink
I get this message when I execute upgrade 35 to 351.sql:
Command completed successfully
Incorrect syntax near the keyword 'LIKE'
Is it supposed to say "Incorrect syntax..." or do I have a big problem now? 😃
Don't worry about it, the update was for special unicode characters (chinese)
Most likely a setting on the sqlserver that was changed after the initial installation.
josteink
That works. What am I looking for?
It isn't supposed to say this.
The error is on view "dbo.web30searchuser"
Could you try searching for a user in the webpage?
