KHabershon
Anyone else seeing an issue where the transaction logs in the database are filling up the drive? The DB is eating up anywhere from 19-25 gigs and then the DB fails since it's not committing those records to the DB. I'm not a DBA so if there's something that I need to turn off please advise.
Please contact us by e-mail to take a look at the problem.
KHabershon
Yes, recovery is set to simple. Yes, but the database is not backed up nightly. The logs are filling up in a matter of 4-5 hours.[img][/img]
Can you check if the database is set to "simple" mode.
A backup of the database should also clear the log.
