kaarde
Here's a small command that will start dameware mini remote on the machine you are viewing, i know it's not free but it does a great job.
\\SERVER\SHARE$\dwmrc\dwrcc.exe -c: -m:{computer}
You will need to have dameware installed on the server.
For all those who use Dameware
Hope someone likes it
DGoodwin
Do you only have the mini remote installed and not the full package?
ESIT
I'm running Vista 64bit and changed the path to this:
"C:\Program Files (x86)\DameWare Development\DameWare Mini Remote Control\DWRCC.exe" -m:{computer}
It says file not found when I try to launch from the web console even though I run it directly from there on my machine.
DGoodwin
You can also use "C:\Program Files\DameWare Development\DameWare NT Utilities\dwrcc.exe" -m:{computer} and this will launch Dameware Remote from the "Tech's" machine. Therefore, if any of my team members have dameware installed, they can use it. It does not open it up to anyone who has the web interface, just the techs.
