about 30% of our machies still appear in red.
Running triggered scan from console or even manually on the machines doesn't help.
It is same machines as the others, in the same domain, running Windows XP SP3. Some with a clean installation, so it can't be OS/configuration related.
Where can I find a log with the reason scan failes?
Is there another way to run scan that might work?
Thanks,
Nirs
