Can anybody confirm that the following startup.vbs placed in a logon script thru GPO is correct?
Set WshShell = CreateObject("WScript.Shell")
WshShell.run "ONESOURCESBS\netlogon\lsclient.exe FILESERVER",0
where ONESOURCESBS is the DC
FILESERVER is the machine name where the lansweeper service is installed.
Also I have attached the service conf file as well.
<configuration>
<appSettings>
<add key="MM_CONNECTION_STRING_Lansweeper" value="Persist Security Info=False;Data Source=1SOURCEERP;Initial Catalog=lansweeperdb;User ID=lansweeperuser;Password=XXXXXXXXXXXXXXXX" />
<add key="ConcurrentThreads" value="20" />
<add key="ListenPort" value="9524" />
<add key="Activescanning" value="1" />
</appSettings>
</configuration>
In this point the web console accessed through the http://localhost:8530/lansweeper32/
stills gives me the following error
System.Data.SqlClient.SqlException: Login failed for user 'lansweeperuser'.
I still get the lsclient machinename check to fail on every computer?
C:\>\\onesourcesbs\netlogon\lsclient pce0006
Lansweeper client
Connecting...
Failed
C:\>\\onesourcesbs\netlogon\lsclient fileserver
Lansweeper client
Connecting...
Failed
C:\>\\onesourcesbs\netlogon\lsclient onesouresbs
Lansweeper client
Connecting...
Failed
C:\>\\onesourcesbs\netlogon\lsclient 1sourceerp
Lansweeper client
Connecting...
Failed
Is there some setting which I have omitted by accident?
