TelhioCU
I have received a solution that did not work to correct my issues with securing access to the web console.
The documentation states to add the approved group name/s to the web.config file. I have done so without success. Additionally, I have attempted to use "allowed" users and had no success.
Changing the permissions in IIS/NTFS works to prevent users from getting to the site without authentication, however it also prevents proper use of the web console by causing web application errors.
I really need to get a solution for this problem.
Thanks,
TCU
Attached is the web.config that is in place now, as well as one I have edited to deploy the group restriction without success.
This one is operational without any security settings:
<configuration>
<appSettings>
<add key="MM_CONNECTION_HANDLER_Lansweeper" value="sqlserver.htm"/>
<add key="MM_CONNECTION_STRING_Lansweeper" value="Persist Security Info=False;Data Source=BR01SQL03;Initial Catalog=Lansweeper32;User ID=xxxxxxxxx;Password=xxxxxxxxxx"/>
<add key="MM_CONNECTION_DATABASETYPE_Lansweeper" value="SQLServer"/>
<add key="MM_CONNECTION_SCHEMA_Lansweeper" value=""/>
<add key="MM_CONNECTION_CATALOG_Lansweeper" value=""/>
<add key="dateformat" value="dd/MM/yyyy"/>
</appSettings>
<system.web>
<compilation debug="true" strict="false" explicit="true">
<assemblies>
<add assembly="System.Web.Extensions, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35"/>
<add assembly="System.Design, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/>
<add assembly="System.Web.Extensions.Design, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35"/>
<add assembly="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B77A5C561934E089"/>
</assemblies>
</compilation>
<httpHandlers><remove verb="*" path="*.asmx"/>
<add verb="*" path="*.asmx" type="System.Web.Script.Services.ScriptHandlerFactory" validate="false"/>
<add verb="*" path="*_AppService.axd" type="System.Web.Script.Services.ScriptHandlerFactory, System.Web.Extensions, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" validate="false"/>
<add verb="GET,HEAD" path="ScriptResource.axd" type="System.Web.Handlers.ScriptResourceHandler, System.Web.Extensions, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" validate="false"/>
</httpHandlers>
<httpModules>
<add name="ScriptModule" type="System.Web.Handlers.ScriptModule, System.Web.Extensions, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/>
</httpModules></system.web>
</configuration>
This one has the recommended security settings and does not work:
<configuration>
<appSettings>
<add key="MM_CONNECTION_STRING_Lansweeper" value="Persist Security Info=False;Data Source=BR01SQL03;Initial Catalog=Lansweeper32;User ID=lssqluser32;Password=mysecretpassword0*"/>
</appSettings>
<system.web>
<authentication mode="Windows"/>
<authorization>
<allow roles="domain\my dept" />
<deny users="*" />
</authorization>
<assemblies>
</assemblies>
</compilation>
</httpHandlers>
<httpModules>
</configuration>
Once put the security in place, from a remote PC when I try to open the website I get the following error:
Server Error in '/lansweeper32' Application.
Access is denied.
Description: An error occurred while accessing the resources required to serve this request. The server may not be configured for access to the requested URL.
Error message 401.2.: Unauthorized: Logon failed due to server configuration. Verify that you have permission to view this directory or page based on the credentials you supplied and the authentication methods enabled on the Web server. Contact the Web server's administrator for additional assistance.
However, if I login on the local LanSweeper32 machine (as the same account I am attempting to use from the remote location) everything works fine!
The IIS Settings have anonymous enabled, along with integrated windows security. That is all.
21 REPLIES 21
<compilation debug="True" strict="false" explicit="true"> should end with "/>" instead of ">"
like this:
<compilation debug="True" strict="false" explicit="true"/>
Could you please attach your config file to the post please. (instead of copy/paste)
Please also attach a screenshot of your complete errorpage in internet explorer.
mz3prs
OK uploaded
mz3prs
I am having a similar issue with the authentication and I get the following error message.
Configuration Error
Description: An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately.
Parser Error Message: Unrecognized element 'authorization'.
Source Error:
Line 13: <identity impersonate="true" />
Line 14: <compilation debug="True" strict="false" explicit="true">
Line 15: <authorization>
Line 16: <allow roles="domain\group name" />
Line 17: <deny users="*" />
Source File: C:\Program Files\lansweeper32\website\web.config Line: 15
Under IIS I have the following setting...Directory Security>Authentication and Access Control
Unchecked - Enable Anonymous Access
Checked - Intergrated Windows Authentication
Here is a copy of my web.config file...
<configuration>
<appSettings>
<add key="MM_CONNECTION_STRING_Lansweeper" value="Persist Security Info=False;Data Source=SERVERNAME;Initial Catalog=Lansweeper32;User ID=lssqluser32;Password=mysecretpassword0*"/>
</appSettings>
<system.web>
<identity impersonate="true"/>
<authorization>
<allow roles="domainname\group name" />
<deny users="*" />
</authorization>
<assemblies>
</assemblies>
</compilation>
<httpHandlers>
</httpHandlers>
<httpModules>
</httpModules>
</system.web>
</configuration>
It looks the same as everyone else, so I don't understand why it is not working.
Illuminator7532
What about trying to secure the webconsole via IIS based on ip-adresses ? Wouldn't that be much simpler ? Give your own computer a reserved dhcp address, register that ip-address in IIS and you're done
aquateen
Possibly, but I was able to get it to work when I used the Domain Admins group so.....
Might be a problem with the "space" in the group name?
DGoodwin
Here's what I found. My site security is only "Integrated Windows Authentication" The Groups were not working, so i added the users manually and it all works fine. See below.
<configuration>
<appSettings>
<add key="MM_CONNECTION_STRING_Lansweeper" value="Persist Security Info=False;Data Source=RALINV01;Initial Catalog=Lansweeper32;User ID=lssqluser32;Password=mysecretpassword0*"/>
<add key="dateformat" value="MM/dd/yyyy"/>
</appSettings>
<system.web>
<compilation debug="false" strict="false" explicit="true">
<assemblies>
</assemblies>
</compilation>
<httpHandlers>
</httpHandlers>
<httpModules>
</httpModules>
<authorization>
<allow users="domain\name1, domain\name2, domain\name3, domain\name4, domain\name5, domain\name6, domain\name7" />
<deny users="*" />
</authorization>
</system.web>
</configuration>
aquateen
After about a half-hour of trail and error yesterday, it seems you have to put the suggested configuration changes in the XML (I believe xml) conf file in a specific order.
<configuration><appSettings><add key="MM_CONNECTION_HANDLER_Lansweeper" value="sqlserver.htm"/><add key="MM_CONNECTION_STRING_Lansweeper" value="Persist Security Info=False;Data Source=SERVERNAME;Initial Catalog=Lansweeper32;User ID=lssqluser32;Password=YOURPASSWORD*"/><add key="MM_CONNECTION_DATABASETYPE_Lansweeper" value="SQLServer"/><add key="MM_CONNECTION_SCHEMA_Lansweeper" value=""/><add key="MM_CONNECTION_CATALOG_Lansweeper" value=""/><add key="dateformat" value="dd/MM/yyyy"/></appSettings><system.web><authentication mode="Windows"/><identity impersonate="true"/><compilation debug="false" strict="false" explicit="true"><assemblies><add assembly="System.Web.Extensions, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=23894723040"/><add assembly="System.Design, Version=2.0.0.0, Culture=neutral, PublicKeyToken=45u9083459"/><add assembly="System.Web.Extensions.Design, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=901238478123904"/><add assembly="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B3457439857430"/></assemblies></compilation><httpHandlers><remove verb="*" path="*.asmx"/><add verb="*" path="*.asmx" type="System.Web.Script.Services.ScriptHandlerFactory" validate="false"/><add verb="*" path="*_AppService.axd" type="System.Web.Script.Services.ScriptHandlerFactory, System.Web.Extensions, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=358-548-543" validate="false"/><add verb="GET,HEAD" path="ScriptResource.axd" type="System.Web.Handlers.ScriptResourceHandler, System.Web.Extensions, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" validate="false"/></httpHandlers><httpModules><add name="ScriptModule" type="System.Web.Handlers.ScriptModule, System.Web.Extensions, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/></httpModules><authorization><allow roles="YOURDOMAIN\YOURDOMAINGROUP"/><deny users="*"/></authorization></system.web></configuration>
I also disabled anonymous access.
Please don't copy and paste this, as I have modified several things for security purposes; just take note of the order in which the tags or elements are placed.
Sorry it's not laid out better, that's the way the file is by default and my IDE editor isn't working right now.
Hope this helps.
Could you upload (as attachment) your complete web.config file please.
Could you also upload a complete screenshot of the webpage error that you are getting.
