TelhioCU
I have received a solution that did not work to correct my issues with securing access to the web console.
The documentation states to add the approved group name/s to the web.config file. I have done so without success. Additionally, I have attempted to use "allowed" users and had no success.
Changing the permissions in IIS/NTFS works to prevent users from getting to the site without authentication, however it also prevents proper use of the web console by causing web application errors.
I really need to get a solution for this problem.
Thanks,
TCU
Attached is the web.config that is in place now, as well as one I have edited to deploy the group restriction without success.
This one is operational without any security settings:
<configuration>
<appSettings>
<add key="MM_CONNECTION_HANDLER_Lansweeper" value="sqlserver.htm"/>
<add key="MM_CONNECTION_STRING_Lansweeper" value="Persist Security Info=False;Data Source=BR01SQL03;Initial Catalog=Lansweeper32;User ID=xxxxxxxxx;Password=xxxxxxxxxx"/>
<add key="MM_CONNECTION_DATABASETYPE_Lansweeper" value="SQLServer"/>
<add key="MM_CONNECTION_SCHEMA_Lansweeper" value=""/>
<add key="MM_CONNECTION_CATALOG_Lansweeper" value=""/>
<add key="dateformat" value="dd/MM/yyyy"/>
</appSettings>
<system.web>
<compilation debug="true" strict="false" explicit="true">
<assemblies>
<add assembly="System.Web.Extensions, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35"/>
<add assembly="System.Design, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/>
<add assembly="System.Web.Extensions.Design, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35"/>
<add assembly="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B77A5C561934E089"/>
</assemblies>
</compilation>
<httpHandlers><remove verb="*" path="*.asmx"/>
<add verb="*" path="*.asmx" type="System.Web.Script.Services.ScriptHandlerFactory" validate="false"/>
<add verb="*" path="*_AppService.axd" type="System.Web.Script.Services.ScriptHandlerFactory, System.Web.Extensions, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" validate="false"/>
<add verb="GET,HEAD" path="ScriptResource.axd" type="System.Web.Handlers.ScriptResourceHandler, System.Web.Extensions, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" validate="false"/>
</httpHandlers>
<httpModules>
<add name="ScriptModule" type="System.Web.Handlers.ScriptModule, System.Web.Extensions, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/>
</httpModules></system.web>
</configuration>
This one has the recommended security settings and does not work:
<configuration>
<appSettings>
<add key="MM_CONNECTION_STRING_Lansweeper" value="Persist Security Info=False;Data Source=BR01SQL03;Initial Catalog=Lansweeper32;User ID=lssqluser32;Password=mysecretpassword0*"/>
</appSettings>
<system.web>
<authentication mode="Windows"/>
<authorization>
<allow roles="domain\my dept" />
<deny users="*" />
</authorization>
<assemblies>
</assemblies>
</compilation>
</httpHandlers>
<httpModules>
</configuration>
Once put the security in place, from a remote PC when I try to open the website I get the following error:
Server Error in '/lansweeper32' Application.
Access is denied.
Description: An error occurred while accessing the resources required to serve this request. The server may not be configured for access to the requested URL.
Error message 401.2.: Unauthorized: Logon failed due to server configuration. Verify that you have permission to view this directory or page based on the credentials you supplied and the authentication methods enabled on the Web server. Contact the Web server's administrator for additional assistance.
However, if I login on the local LanSweeper32 machine (as the same account I am attempting to use from the remote location) everything works fine!
The IIS Settings have anonymous enabled, along with integrated windows security. That is all.
21 REPLIES 21
TelhioCU
Ok, this is getting insane!
Here is my web.config:
<configuration>
<appSettings>
<add key="MM_CONNECTION_STRING_Lansweeper" value="Persist Security Info=False;Data Source=BR01SQL03;Initial Catalog=Lansweeper32;User ID=xxxxxxx;Password=xxxxxx"/>
</appSettings>
<system.web>
<identity impersonate="true" />
<authorization>
<allow roles="domain\group name" />
<deny users="*" />
</authorization>
<assemblies>
</assemblies>
</compilation>
</httpHandlers>
<httpModules>
</httpModules>
</system.web>
</configuration>
Now it is giving me this error message:
Configuration Error
Description: An error occurred during the processing of a configuration file required to service this request. Please review the specific error details below and modify your configuration file appropriately.
Parser Error Message: Unrecognized element 'authorization'.
Source Error:
Line 12: <identity impersonate="true" />
Line 13: <compilation debug="true" strict="false" explicit="true">
Line 14: <authorization>
Line 15: <allow roles="domain\group name" />
Line 16: <deny users="*" />
Source File: C:\Program Files\lansweeper32\website\web.config Line: 14
Is it really this hard?
UGH!
See this thread : http://forum.lansweeper.com/yaf_postst382_Access-to-Lansweeper-by-group-membership.aspx
You must also disable anonymous access
