bitos
I have been moving around lots of assets from one switch to another.
The (depricated) asset info still shows up on the old switch network interface list.
On the asset page, both the old and the new switch interface are showing.
Rescanning the old switch, the new switch and the asset itself does not help.
Is it possible to clear the depricated asset info on a switch's list of network interfaces?
Thanks!
Just an FYI for everyone: in the Lansweeper 6.0 beta, there is now a button in the Asset Options of the switch page to manually delete any old connection data. If you are interested in a download link for the beta, please contact support@lansweeper.com and include "beta" in the title of your message.
No, this isn't possible. The switch page will list the last asset to be connected to each port. This is expected behavior and cannot be changed. Note that there is a date next to each asset connection indicating when the asset was connected to the port.
The asset page of the connected asset should only show the last switch connection, *if* you are using the latest Lansweeper release. Our latest installer can be found here: http://lansweeper.com/Download.aspx
Update instructions can be found on page 190 and beyond of our online documentation: http://www.lansweeper.com/documentation.pdf
