timglass
I have the web page up and i can run the lsclient.exe at the machine but all i get is the machine name and username. The error i get at the web page is The network path was not found. The error listed in the subject line is from the server error log. When i run the test connection program i get
Ping test OK
Remote registry test FAILED
Remote WMI access test OK
Remote \\127.0.0.1\c$ access test OK
35 REPLIES 35
Have you checked the reverse dns lookup?
Are the clients firewalled?
timglass
None those are the only ones i have tried it on.
How many machines are working?
timglass
Three different errors on three different machines:
Pingerror Ping failed to AAC-TGLASSKY
Regerror The network path was not found. AAC-AHALLKY
Wmierror The RPC server is unavailable. (Exception from HRESULT: 0x800706BA) AAC-KGREGORYKY
Do you get this error on all your clients?
timglass
any update on this?
timglass
i am running the remote registry service on the client and given the lsscanner login admin rights both on the local mahine and as a domain admin. I have remote desktop enabled on the client as well.
Regerror Requested registry access is not allowed
This means that your user running the service does not have registry access to the client
timglass
Which is how i have it setup.
The database and lansweeper are on the same server.
The service is running with admin rights.
Euh no
Typical setup:
Database on a server
Lansweeper service on one server connecting to the database
clients connecting to the lansweeper service with lsclient
