wavin
Hello ,
we are using LS for more than 250 clients and everything works fine ! Congratulation for the execelent product , we will buy the premium edition asap.
Only one computer has problems and we don't understand why.
The error in the PC web page is : RegError --> The network path was not found.
The result of connection tester is :
Ping test OK
Remote registry test FAILED
Impossibile trovare il percorso di rete.
Remote WMI access test OK
Remote \\pc118\c$ access test FAILED
In the error log file , there is nothing about this PC
The reverse lookup doesn't work for this PC , BUT IT DOESN'T WORK FOR ANY OTHER PC in our domain and the other PC work with LSweeper
Can you help me ? I don't understand why it doesn't work just for this PC !
Many thankx
PS : We have just moved to version 3.2 , but the problem is the same.
Wv
12 REPLIES 12
wavin
Ciao ,
the problem has been solved !!!! IT was disabled "file and printer sharing for Microsoft Networks" !!
Thanks a lot for your help
wavin
This is the netsh firewall show state for a PC that is working.
As you can see the Remote Admin Mode ( it is in italian = Modalità amministrazione remota ) is disabled.....
C:\Documents and Settings\aro>netsh firewall show state
Stato firewall:
Profilo = Domain
Modalità operativa = Disable
Modalità eccezioni = Enable
Modalità risposta multicast/broadcast = Enable
Modalità notifiche = Enable
Versione criterio di gruppo = Windows Firewall
Modalità amministrazione remota = Disable
Porte attualmente aperte su tutte le interfacce di rete:
Porta Prot. Versione Programma
10243 TCP IPv4 (null)
10280 UDP IPv4 (null)
10281 UDP IPv4 (null)
10282 UDP IPv4 (null)
10283 UDP IPv4 (null)
10284 UDP IPv4 (null)
2869 TCP IPv4 (null)
1900 UDP IPv4 C:\WINDOWS\system32\svchost.exe
dgarza1
i had the same problem and found out the user had disabled "file and printer sharing for Microsoft Networks" in the properties of his NIC.
Can you post a "netsh firewall show state" for the computers that are working
wavin
Remote admin mode = Disable ?!?!
Why do I need to enable remote exception in my policies ??
This is disabled for everyone , but only for 1 single PC doesn't work !
wavin
Also the reverse lookup problem has been solved , but this PC is still not working .....
C:\Documents and Settings\aro>ping -a 192.168.1.37
Esecuzione di Ping pc118.wavinspa [192.168.1.37] con 32 byte di dati:
Risposta da 192.168.1.37: byte=32 durata=81ms TTL=128
Risposta da 192.168.1.37: byte=32 durata=95ms TTL=128
Risposta da 192.168.1.37: byte=32 durata=16ms TTL=128
Risposta da 192.168.1.37: byte=32 durata=39ms TTL=128
Statistiche Ping per 192.168.1.37:
Pacchetti: Trasmessi = 4, Ricevuti = 4, Persi = 0 (0% persi),
Tempo approssimativo percorsi andata/ritorno in millisecondi:
Minimo = 16ms, Massimo = 95ms, Medio = 57ms
This is the problem :
You need to enable remote admin exception in your policies.
wavin
This is the netsh firewall show state for this PC :
Firewall status:
Profile = Domain
Operational mode = Disable
Exception mode = Enable
Multicast/broadcast response mode = Enable
Notification mode = Enable
Group policy version = Windows Firewall
Ports currently open on all network interfaces:
Port Protocol Version Program
No ports are currently open on all network interfaces.
Could you try from the command prompt : "netsh firewall show state" and post the output here
