adminicrater
- The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
- The RPC server is unavailable. (Exception from HRESULT: 0x800706BA)
out of about 78 systems i have 16 with these errors.
How can I correct this?
Thanks for your time in advance!
By the way, this product is great!!!!!! I will be a premium member as soon as I sort out this last issue.
adminicrater
I had a machine that was red (Dell Optiplex 755) that was behind on its BIOS by quite a bit. Updated it and now it is properly inventoried.
adminicrater
yep loaded Service Pack 3 ( SP3 ) and everything is fine on that machine.
adminicrater
Seems to be my NON-service pack 3 machines??? anyone else experience this? Perhaps SP3 will fix this.. I will verify now
DNS and Reverse DNS seemed fine for the one SP2 machine I am testing now.
adminicrater
as you have said, it appears it is DNS related..
i will verify now.
Thanks again.
As with most/all problems : The system is firewalled/has permissions problems or the reversed lookup is wrong.
