cossie
Hi there.
I have searched the forum for an answor but cant quite figure this one out...
On a test machine Virtual Windows vista i get this error.
Wmierror The RPC server is unavailable. (Exception from HRESULT: 0x800706BA) A01GVVISTA (172.16.14.122) 2/18/2008 11:31:46 AM
I have looked at this post amoung others 🙂
http://forum.lansweeper.com/yaf_postst245_WmierrorThe-RPC-server-is-unavailable-Exception-from-HRESULT-0x800706BA.aspx
The test connection works fine
firewall disabled
Dcom enabled
Remote registry service is started
the machine can ping the Lansweeper server an can make a reverse dns lookup
There is nothing written in the Errorlog.txt
Any ideas where my problem is?
How many pc's are affected by this problem.
Is this only on one vista computer?
cossie
Yes i only have this problem on one Vista also the only vista running virtually, it is primarely for testing purpose i have only 4 vista machines installed and 700 2000/xp pc's.
cossie
Yes it works without any problems.
Microsoft Windows [version 6.0.6000]
Copyright (c) 2006 Microsoft Corporation. Alle rettigheder forbeholdes.
H:\>ping -a 172.16.1.95
Pinger testsrv1.herlev.local [172.16.1.95] med 32 byte data:
Svar fra 172.16.1.95: byte=32 tid=6ms TTL=128
Svar fra 172.16.1.95: byte=32 tid<1ms TTL=128
Ping-statistikker for 172.16.1.95:
Pakker: Sendt = 4, modtaget = 4, tabt = 0 (0% tab),
Beregnet tid for rundtur i millisekunder:
Minimum = 0ms, Maksimum = 6ms, Gennemsnitlig = 1ms
H:\>ping testsrv1
Svar fra 172.16.1.95: byte=32 tid=7ms TTL=128
Minimum = 0ms, Maksimum = 7ms, Gennemsnitlig = 1ms
H:\>
Does the reverse lookup points to the correct computer name?
