Error log:
6/16/2009 1:06:31 PM: Database connection successful, starting up service
6/16/2009 2:39:01 PM: UHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo)
at System.Management.ManagementObjectCollection.ManagementObjectEnumerator.MoveNext()
at LansweeperService.MdlWmi.GetWMI(String Querystr, String Table, LS_Computer& mycomputer, String section, SqlConnection& sqlcon)
6/16/2009 3:10:59 PM: LNELSON
6/16/2009 3:51:48 PM: Cannot open database "lansweeperdb" requested by the login. The login failed.
Login failed for user 'lansweeperuser'.
at System.Data.Common.DbDataAdapter.QuietOpen(IDbConnection connection, ConnectionState& originalState)
at System.Data.Common.DbDataAdapter.Fill(DataSet dataSet, String srcTable)
at LansweeperService.MdlServiceStatus.WriteServiceStatus()
6/16/2009 9:50:39 PM: MHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/16/2009 11:35:09 PM: UHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/17/2009 12:08:18 AM: LNELSON
6/17/2009 6:37:30 AM: MHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/17/2009 8:23:17 AM: UHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/17/2009 8:34:00 AM: EJAX01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/17/2009 9:11:10 AM: LNELSON
6/17/2009 2:12:15 PM: BOFDJANE01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/17/2009 2:54:10 PM: MHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/17/2009 5:09:20 PM: UHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/17/2009 5:33:03 PM: ITRBELL01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/17/2009 6:12:31 PM: LNELSON
6/17/2009 11:40:04 PM: MHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/18/2009 1:55:33 AM: UHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/18/2009 3:13:52 AM: LNELSON
6/18/2009 8:27:15 AM: MHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/18/2009 9:46:23 AM: UHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/18/2009 12:16:00 PM: LNELSON
6/18/2009 5:01:15 PM: ITRBELL01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/18/2009 6:33:32 PM: UHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/18/2009 9:17:22 PM: LNELSON
6/18/2009 11:17:57 PM: BODATA04 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/19/2009 3:30:12 AM: UHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/19/2009 6:04:18 AM: LNELSON
6/19/2009 8:16:41 AM: MHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/19/2009 8:31:32 AM: ITRBELL01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/19/2009 8:31:32 AM: ITRBELL01 Access is denied. (Exception from HRESULT: 0x80070005 (E_ACCESSDENIED))
at System.Management.ManagementObjectSearcher.Get()
at LansweeperService.sweeperthread.GetTheUsersAndGroups(LS_Computer mycomputer, String section, SqlConnection& sqlcon)
6/19/2009 9:50:00 AM: WMPACSSTORAGE01 Cannot find table 0.
at System.Data.DataTableCollection.get_Item(Int32 index)
at LansweeperService.sweeperthread.UpdateLastScan(LS_Computer mycomputer, String section, SqlConnection& sqlcon, DateTime startdate)
at LansweeperService.MdlRegistry.LSRegistry(LS_Computer& mycomputer, String section, SqlConnection& sqlcon)
6/19/2009 12:06:22 PM: BOPACSDXIT01
6/19/2009 12:17:03 PM: UHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/19/2009 3:06:08 PM: LNELSON
6/19/2009 4:17:44 PM: MHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/19/2009 9:03:33 PM: UHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/19/2009 11:38:55 PM: TXTEMP01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/20/2009 12:06:36 AM: LNELSON
6/20/2009 12:08:05 AM: MHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/20/2009 5:39:48 AM: UHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/20/2009 8:21:24 AM: MHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/20/2009 9:09:22 AM: LNELSON
6/20/2009 2:26:24 PM: UHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/20/2009 5:07:23 PM: MHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/20/2009 6:10:23 PM: LNELSON
6/20/2009 7:39:27 PM: Cannot open database "lansweeperdb" requested by the login. The login failed.
6/20/2009 11:23:05 PM: UHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/21/2009 1:53:18 AM: MHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/21/2009 3:11:48 AM: LNELSON
6/21/2009 7:58:46 AM: UHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/21/2009 10:40:44 AM: MHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/21/2009 12:13:42 PM: LNELSON
6/21/2009 1:55:06 PM: Cannot open database "lansweeperdb" requested by the login. The login failed.
6/21/2009 4:56:24 PM: UHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/21/2009 7:26:38 PM: MHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/21/2009 9:14:47 PM: LNELSON
6/21/2009 11:45:42 PM: TXTEMP01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
at System.Management.ManagementObject.InvokeMethod(String methodName, ManagementBaseObject inParameters, InvokeMethodOptions options)
6/22/2009 1:42:32 AM: UHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/22/2009 3:45:42 AM: SDPACSDX02 Value cannot be null.
Parameter name: value
at System.Management.ManagementObjectSearcher.set_Scope(ManagementScope value)
6/22/2009 4:02:31 AM: MHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/22/2009 6:16:55 AM: LNELSON
6/22/2009 10:29:21 AM: UHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/22/2009 1:00:20 PM: MHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/22/2009 3:18:05 PM: LNELSON
6/22/2009 3:48:54 PM: BODATA04 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/22/2009 7:15:30 PM: UHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/22/2009 7:15:51 PM: SDWKS13 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/22/2009 9:45:51 PM: MHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/23/2009 12:04:08 AM: LNELSON
6/23/2009 4:02:18 AM: UHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/23/2009 6:33:20 AM: MHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/23/2009 9:06:52 AM: LNELSON
6/23/2009 10:51:51 AM: CRSCHED09 Not found
at System.Management.ManagementException.ThrowWithExtendedInfo(ManagementStatus errorCode)
at System.Management.ManagementObject.Initialize(Boolean getObject)
at System.Management.ManagementBaseObject.get_wbemObject()
at System.Management.ManagementObject.get_ClassPath()
at System.Management.ManagementObject.GetMethodParameters(String methodName, ManagementBaseObject& inParameters, IWbemClassObjectFreeThreaded& inParametersClass, IWbemClassObjectFreeThreaded& outParametersClass)
at System.Management.ManagementObject.GetMethodParameters(String methodName)
6/23/2009 12:38:10 PM: UHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/23/2009 3:19:55 PM: MHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/23/2009 6:07:59 PM: LNELSON
6/23/2009 8:09:29 PM: SERICKSON The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/23/2009 9:24:16 PM: UHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/24/2009 12:05:57 AM: MHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/24/2009 3:09:29 AM: LNELSON
6/24/2009 6:23:52 AM: UHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/24/2009 8:54:19 AM: MHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/24/2009 2:59:44 PM: UHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/24/2009 3:13:59 PM: LNELSON
6/24/2009 3:44:16 PM: BODATA03 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/24/2009 5:41:08 PM: MHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/24/2009 11:56:53 PM: UHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/25/2009 2:27:29 AM: MHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/25/2009 8:44:25 AM: UHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/25/2009 10:29:37 AM: MHRAD01 The remote procedure call failed. (Exception from HRESULT: 0x800706BE)
6/25/2009 12:18:25 PM: ECRW01 SHUTDOWN is in progress.
at LansweeperService.mdlFiles.LSFiles(LS_Computer Mycomputer, String section, SqlConnection& sqlcon)
