Andre_G
Is there a spec sheet that indentifies the hardware configuration settings for a Virtual server configuration?
We have bumped it up the 3GB of memory and it's still demanding more.
Andre
SQL server will take as much memory as you can give it.
For performance I recommend:
1 virtual machine for scanning, 4 virtual processors (or more), memory is not that important
1 virtual machine for sqlserver, 4 virtual processors (or more), 2GB ram (or more if you have more)
Setting the logging mode for the database to "simple"
Andre_G
Perhaps the performace issues could be related to the 2005 SQL server running on they same VM. Are they known issues with running both together on the same box for 30,000+ assets?
Andre
Are you talking about the lansweeper server installed on a virtual server?
The service should only take about 100mb maximum.
