itadmin2
When visiting the Web Console it still is not working...
http://localhost:8530/lansweeper32/
System.Data.SqlClient.SqlException: Login failed for user 'lansweeperuser'.
old version
<configuration>
<appSettings>
<add key="ConnectionString" value="Persist Security Info=False;Data Source=1SOURCEERP;Initial Catalog=lansweeperdb;User ID=lansweeperuser;Password=XXXXXXXXXXXXXXXX" />
<add key="ConcurrentThreads" value="20" />
<add key="ListenPort" value="9524" />
<add key="Activescanning" value="1" />
</appSettings>
</configuration>
Running version
<configuration>
<appSettings>
<add key="MM_CONNECTION_STRING_Lansweeper" value="Persist Security Info=False;Data Source=1SOURCEERP;Initial Catalog=lansweeperdb;User ID=lansweeperuser;Password=XXXXXXXXXXXXXXXX" />
</appSettings>
</configuration>
16 REPLIES 16
domain admin rights -> OK
Could you please
1) stop the lansweeper service
2) Delete the errorlog.txt file
3) start the lansweeper service
Post your errorlog if you are experiencing problems again.
itadmin2
Yes the fileserver is connected to the domain.
The lansweeper service was executed with local admin rights, but now I have changed it to domain admin rights account.
Is fileserver connected to a domain?
Under which service is the lansweeper service running?
itadmin2
I have installed the beta version of the lansweeperservice as suggested and I have attached the new errorlog file as well.
Please download an updated (beta) version of the lansweeperservice from this url :
http://www.lansweeper.com/debug/debugbeta2.zip
Please send me a new errorlog file afterwards.
itadmin2
Yes indeed the telnet to the machine at port 9524 works, displaying a blank command screen with a cursor blinking.
Could you try (from the client to fileserver): "telnet fileserver 9524"
You should get a black command screen with a cursor blinking.
Also please upload your errorlog.txt file
itadmin2
by running netstat -a on the server where the service is installed i can confirm that the server is listening on port 9524 (like described on page 33 of documentation.pdf).
Should the same be done for all other servers which the windows firewall is started?
It still displays on the web console only 6 systems registered and scanning has been performed for almost one day?
Could it be that a firewall on "fileserver" is blocking the access from lsclient? (standard port 9524)
