itadmin2
When visiting the Web Console it still is not working...
http://localhost:8530/lansweeper32/
System.Data.SqlClient.SqlException: Login failed for user 'lansweeperuser'.
old version
<configuration>
<appSettings>
<add key="ConnectionString" value="Persist Security Info=False;Data Source=1SOURCEERP;Initial Catalog=lansweeperdb;User ID=lansweeperuser;Password=XXXXXXXXXXXXXXXX" />
<add key="ConcurrentThreads" value="20" />
<add key="ListenPort" value="9524" />
<add key="Activescanning" value="1" />
</appSettings>
</configuration>
Running version
<configuration>
<appSettings>
<add key="MM_CONNECTION_STRING_Lansweeper" value="Persist Security Info=False;Data Source=1SOURCEERP;Initial Catalog=lansweeperdb;User ID=lansweeperuser;Password=XXXXXXXXXXXXXXXX" />
</appSettings>
</configuration>
16 REPLIES 16
itadmin2
issue is fixed. thanks for your assistance.
Looking at the dashboard section of the web console, i only see that a few computers have been registered.
Is there something else that I should do, in order to scan the whole network?
Moreover,
by executing
\domaincontrolermachinename\netlogon\lsclient
on serveral server the outcome is failed.
only on the system which has the service, is returned with success.
please advise.
You password was "xxxxxx" in the other config file.
Is the password correct in your web.config file?
do i have to make sure that the password in the same in both files? i.e
by changing the value of Password=mysecretpassword0*; in the config file?
itadmin2
<configuration>
<appSettings>
<add key="MM_CONNECTION_HANDLER_Lansweeper" value="sqlserver.htm"/>
<add key="MM_CONNECTION_STRING_Lansweeper" value="Persist Security Info=False;Data Source=1SOURCEERP;Initial Catalog=lansweeperdb;User ID=lansweeperuser;Password=mysecretpassword0*;Connect Timeout=120"/>
<add key="MM_CONNECTION_DATABASETYPE_Lansweeper" value="SQLServer"/><add key="MM_CONNECTION_SCHEMA_Lansweeper" value=""/>
<add key="MM_CONNECTION_CATALOG_Lansweeper" value=""/>
<add key="dateformat" value="dd/MM/yyyy"/>
</appSettings>
<system.web>
<compilation debug="false" strict="false" explicit="true">
<assemblies><add assembly="System.Web.Extensions, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35"/>
<add assembly="System.Design, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/>
<add assembly="System.Web.Extensions.Design, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35"/>
<add assembly="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B77A5C561934E089"/>
</assemblies>
</compilation>
<httpHandlers>
<remove verb="*" path="*.asmx"/>
<add verb="*" path="*.asmx" type="System.Web.Script.Services.ScriptHandlerFactory" validate="false"/>
<add verb="*" path="*_AppService.axd" type="System.Web.Script.Services.ScriptHandlerFactory, System.Web.Extensions, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" validate="false"/>
<add verb="GET,HEAD" path="ScriptResource.axd" type="System.Web.Handlers.ScriptResourceHandler, System.Web.Extensions, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" validate="false"/>
</httpHandlers>
<httpModules>
<add name="ScriptModule" type="System.Web.Handlers.ScriptModule, System.Web.Extensions, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/>
</httpModules>
</system.web>
</configuration>
This is the configuration file for your service, could you also post your web.config file please.
So your service is running with this connection and your webconsole isn't?
Correct?
Correct?
Yes that is correct.
The service is running on the machine servername FILESERVER but the web console is not.
