dlwright
I get this after I upgraded from 3.2 to 3.5. Any ideas on what this means. Lansweeper32 is the folder name but it has the 3.5 version files updated to it. Thanks.
Server Error in '/lansweeper32' Application.
Column 'nonactive' does not belong to table theTable.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.ArgumentException: Column 'nonactive' does not belong to table theTable.
Source Error:
The source code that generated this unhandled exception can only be shown when compiled in debug mode. To enable this, please follow one of the below steps, then request the URL:
1. Add a "Debug=true" directive at the top of the file that generated the error. Example:
<%@ Page Language="C#" Debug="true" %>
or:
2) Add the following section to the configuration file of your application:
<configuration>
<system.web>
<compilation debug="true"/>
</system.web>
</configuration>
Note that this second technique will cause all files within a given application to be compiled in debug mode. The first technique will cause only that particular file to be compiled in debug mode.
Important: Running applications in debug mode does incur a memory/performance overhead. You should make sure that an application has debugging disabled before deploying into production scenario.
Stack Trace:
[ArgumentException: Column 'nonactive' does not belong to table theTable.]
System.Data.DataRow.GetDataColumn(String columnName) +1775301
System.Data.DataRow.get_Item(String columnName) +13
ASP.state_aspx.__Render__control1(HtmlTextWriter __w, Control parameterContainer) +1154
System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +256
System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) +19
System.Web.UI.Page.Render(HtmlTextWriter writer) +29
System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +27
System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +99
System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +25
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1266
Most likely the upgrade sql script timed out.
Try to run it again from the sql tools that came with sqlserver.
Pick the correct database and ignore any errors you might encounter.
