Sistemas-IT
Hi;
Finally I upgrade it, just now I finished the upgrade proccedure with upgradescript1.sql it took 1day and 18 hours, uauhh!. Now the database is OK, i can access to the GUIconsole, change options and more, but if I try to open Web Console, fails with the attached error. Any idea? .NetFramework version error?
Thanks in advance
The database needs to be named "lansweeperdb", it you are still using an old name you need to rename it. (also change your config files if needed)
Sistemas-IT
I tried to install Website but when it checks if the database exist I get the attached error, any idea?
The quickest way to fix this would be:
Remove the error-website.
Run the installer, don't select to upgrade, and select to only the website to install.
Sistemas-IT
Yes, is just a copy-paste of web error, attached a screenshot.
Is this the exact error?
Could you post a screenshot of your browser please.
