jmarmo
I am using registered Lansweeper 4 with the built in Lansweeper's web server. I can only access the Web Consile from the computer running Lansweeper. If I use any other computer, the page can't be displayed. Am I missing a setting?
You can create an exception on port 80
Which url do you normally use to access the website.
Which url are the other users using?
jmarmo
http://wi-services
That works on the lansweeper server, but not on other PC's in the domain. If I turn off the firewall it will work on other PC's.
If the server is running on port 81,82,... you will need to open the port in the windows firewall.
jmarmo
How do I find which ports the server is running on?
