PaulVa214
Hi, even though the Gui console shows the license correctly the web console continues to show "freeware version".. What do I need to do to fix this?
Paul
6 REPLIES 6
PaulVa214
Thanks, That was it.. not in folder..
appreciate!!!
The file helperfunctions.dll should be in the same folder as your lansweeper service. (check the zip file)
PaulVa214
5/8/2009 2:48:35 PM: Database connection successful, starting up service
5/8/2009 4:02:19 PM: Stopping service
5/8/2009 4:02:23 PM: Database connection successful, starting up service
5/8/2009 4:02:23 PM: Could not load file or assembly 'Helperfunctions, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
at LansweeperService.MdlLicenceCode.Validatelicensecode(Int32& returncode, String licensecode, String& returndate)
at LansweeperService.MdlLicenceCode.checklicense()
at LansweeperService.starter.startsweeper()
5/8/2009 4:54:44 PM: Cannot connect to database, check your config file, will try again in 1 minute
A connection was successfully established with the server, but then an error occurred during the login process. (provider: TCP Provider, error: 0 - The specified network name is no longer available.)
5/8/2009 4:55:44 PM: Database connection successful, starting up service
5/8/2009 4:55:44 PM: Could not load file or assembly 'Helperfunctions, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
5/13/2009 10:14:41 AM: Stopping service
5/13/2009 10:14:44 AM: Database connection successful, starting up service
5/13/2009 10:14:44 AM: Could not load file or assembly 'Helperfunctions, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
Please check your errorlog.txt file for any errors.
PaulVa214
It has been since the 8th. This is when I upgraded from 3.1. Has not worked since ;-(
Ian_Bradshaw
Wait a little bit (if you've just done it) ... it took mine 10-15min to update after i'd put the licence in.
Cheers,
I.
