IOCKC
I have a a couple of questions I recently upgraded to 3.1
The wake on lan feature is looking for wol.exe where can I get this tool and where does the .exe need to be so it will work. I would like to place it on a network with other tools so I dont have to have it on the local machine. If there is a path statment that I need to modify let me know.
Also the Asset Links section is not displaying at all, I wasnt sure if there is somthing that I needed to configure to allow that function. I have added a screen shot to for an example.
IOCKC
THanks for the help, I overlooked the actions download link
On the vendor links I just had to re-add them
Thanks again
You can download the wol.exe from the action pack on the download page.
Best is to place all the needed executables in a folder in your windows search path on the computer where you are browsing the website (I use windows\system32)
For the asset links there is a screen in the Management console. (Configuration/asset tag links)
You need to add
Vendor : Dell Computer Corporation
Assetlink : http://support.dell.com/support/topics/global.aspx/support/my_systems_info/details?ServiceTag={assettag}
