Pollak
LS 4.0.0.11 does not appear to display if the OS is either 32bit of 64bit on the Actions Page of the system. However I am able to find it under Configuration> Windows> System. % from the bottom "System Type". A little more work to find it but it is there.
It would be nice to see it on the Actions Page.
Thanks,
Niles
Pollak
Do you have a SQL script that I can load via Lansweeper. I do not have the SQL tools to make this change.
Thanks,
Niles
Thanks,
Niles
The report builder is build in into the configuration tool in 4.0
PierreM
I haven't tried 4.0 yet but you can use the "Report Builder" and create a custom report that you can display on any of the Dashboard board software page.
Here is the simple query that I use.
Select tblComputersystem.Computername, tblComputersystem.SystemType From tblComputersystem Where tblComputersystem.SystemType = 'x64-based PC'
Pierre
(x64) will be shown after the os description if the os is 64 bit in the next beta.
