hagai
Hi Experts,
We've being trying for sometime now to use a very simple powershell command (that is working manually on end clients without any issues), but it doesn't work when running from deployment packages.
we tried using a *.ps1 file , we tried using the command its self, we tried using an encoded command, all working manually on end client, but never within the LanSweeper Deployment Packages.
Any suggestions? why is it so challenging to run a simple command or a script? (the command is creating a folder and copying files from network to local folder, we tested all require permissions and again, are successfully doing so when running this outside the LanSweeper console).
Also, we see there's a limit of 1000 characters in command execution, is this something we can edit or extend?
tnx,
Hagai
David_GF
Hi @hagai,
If all the deployment requirements are met (https://community.lansweeper.com/t5/deploying-software-other-changes/deployment-requirements/ta-p/64...), please contact our support team (https://www.lansweeper.com/contact-support/) as we need to troubleshoot it and will probably need to share your deployment logs.
Sweep that LAN, sweep it!
jaceg_lmi
What ever became of this? What steps were taken? Did you give up and go another route?
David_GF
Hi @hagai,
Deployment Packages
Share topics/ issues related to deployment packages. Please use/rely on content with caution as it is publicly generated.
