howard_cw_lee
Dear Support,
We have two domains in our subnets.
We recently created and added new domain.
However, the newly added domain PCs were failed to scan with the following errors.
Already added the scanning credentials and credential mapping but still failed.
Errors found while scanning:
UPTIME The object invoked has disconnected from its clients. (Exception from HRESULT: 0x80010108 (RPC_E_DISCONNECTED))
ANTIVIRUS Access is denied. (Exception from HRESULT: 0x80070005 (E_ACCESSDENIED))
SERVICES The object invoked has disconnected from its clients. (Exception from HRESULT: 0x80010108 (RPC_E_DISCONNECTED))
HARDDISK The object invoked has disconnected from its clients. (Exception from HRESULT: 0x80010108 (RPC_E_DISCONNECTED))
NETWORK The object invoked has disconnected from its clients. (Exception from HRESULT: 0x80010108 (RPC_E_DISCONNECTED))
SHARES Object reference not set to an instance of an object.
OS The object invoked has disconnected from its clients. (Exception from HRESULT: 0x80010108 (RPC_E_DISCONNECTED))
SOFTWARE The object invoked has disconnected from its clients. (Exception from HRESULT: 0x80010108 (RPC_E_DISCONNECTED))
REGISTRY The object invoked has disconnected from its clients. (Exception from HRESULT: 0x80010108 (RPC_E_DISCONNECTED))
COMPSYSTEM The object invoked has disconnected from its clients. (Exception from HRESULT: 0x80010108 (RPC_E_DISCONNECTED))
COMPSYSPROD The object invoked has disconnected from its clients. (Exception from HRESULT: 0x80010108 (RPC_E_DISCONNECTED))
FrankSc
Scanning multiple domains should be possible if there is a trust between the domains. Since you are seeing Access Denied and RPC errors, we recommend going through the steps in the articles below for troubleshooting this further.
https://www.lansweeper.com/knowledgebase/the-rpc-server-is-unavailable/
https://www.lansweeper.com/knowledgebase/wmi-access-is-denied/
