servicedesk
I noticed some after scanning deployments failed without a target, It's a known issue?
Lansweeper version v. 5305
Deployer version 5.2.4.57
thanks
Daniel_B
This occurs if you have set up a deployment schedule and defined a report as target which does not contain any assets. Repeating deployment logs in this case might be a small bug which will be fixed in one of the later releases of Lansweeper. We recommend removing the deployment schedule under Deployment\Schedules, section Configurations, in such cases.
Bert_D
If it's not to much trouble, could you send an email containing the URL from this post to support@lansweeper.com.
I would like to follow up with some additional questions.
Kind regards
Daniel_B
