LithiumKid1976
Hi
just a quick question for anyone using lansweeper to track their asset.
we want to start asset tagging our systems, which is something we havent done before.
what field do you use in this system, for your asset Tag?
IE i dont see a field listed for asset tag, there is one there for barcode, but what if you dont use a barcode,
i think ill be using an ID, something along the lines of ch00001, Ch00002 CH12023 etc.
what do i do in this case.
tlonde
We used one of the custom fields for our Asset Tags. Seems to be working pretty well for that purpose.
