LabSysadmin
I'd like to do what the subject says.
If anyone know a simple way to achieve that, i'd be very interested.
One way I wanted to do it, is by creating a report with these computers, export to CSV, and then I would need a script to delete all these computers from LS. But LS does not seem to have an Powershell module...
rader
Easiest way is probably Configuration, Server Options and play with the checkbox options under On-premises Active Directory.
LabSysadmin
Thanks but I already tried that, but these options are not flexible.
It must only delete the computers that are in a specific OU.
rader
Only other thing that I can think of is to click on Assets to bring up all the assets, then sort thru the State and OU fields. Once you have that list, you can export a file or Delete all of the assets from this screen.
Can't help with powershell as those skills are lacking in me.
Good luck.
