Dass
I decided to setup Azure scanning on top of the subnet scanning i already had configured for our Azure estate.
The Azure scanning has completed and the resource groups and azure virtual machines are now visible but this has removed the ability to see the software deployed to these Azure machines.
How can i collect both the Azure info around an asset by the Azure Connector and Software inventory via the ip address range scanning?
I don't have the agent deployed to these machines
Dan
shawn
Ah man! Is that what happened to my assets today? I just added Azure scanning and was wondering why my Azure VM assets now show hardly any info. Did you ever find a solution to having both so you can see the Host info as well as the guest VM info? Or do I have to turn off Azure scanning.
