Options
‎04-21-2016 12:26 PM
Is anyone having issues with the calendar still showing deleted events?
Mine still shows the [DEMO] events after deleting the demo data, as well as some test events that I created.
It throws up the following error if I try to move or access them:
Webserver Error
http://lansweeper:81/Calendar/CalendarActions.aspx?action=eventdrop
An unexpected error occurred. To troubleshoot this issue, please contact support@lansweeper.com and provide:
A screenshot of this error message. Include your entire browser window.
Program Files (x86)\Lansweeper\Service\Errorlog.txt, as present on your Lansweeper server.
Program Files (x86)\Lansweeper\Website\App_Data\web_errorlog.txt
Program Files (x86)\Lansweeper\Service\Lansweeperservice.exe.config.
Program Files (x86)\Lansweeper\Website\web.config.
Technical details:
There is no row at position 0.
I'm no database guy but it's pretty easy to assume it's trying to access a record that no longer exists, I'm just wondering why it doesn't also remove the calendar notice as well.
So, bug or feature?
Webserver Error
Technical details:
So, bug or feature?
Solved! Go to Solution.
Labels:
General Discussion
Options
‎05-08-2016 10:42 PM
FYI for everyone: you can now update by following the instructions in this knowledge base article. The latest release includes a bug fix for this issue.
Options
Options
‎04-21-2016 02:18 PM
Awesome, thanks.
Options
‎04-21-2016 01:50 PM
This is a known problem and will be fixed in the next build
Options
‎04-21-2016 12:57 PM
Had the same issue and solved it by restarting IIS.
Options
‎04-21-2016 01:08 PM
Worked a treat, thanks.
Restarting IIS every time might be a bit of a pain though.
