andejo55
See the following article.   Under the certificate section, I'm wondering if anyone has a suggestion on where they've obtained this certificate and instructions on creating it?
https://community.lansweeper.com/t5/scanning-your-network/creating-a-microsoft-cloud-services-applic...
Bruce_B
If you'd like to use a locally generated certificate, you can follow the procedure below, which makes use of Microsoft's Exchange PowerShell Online documentation
  • Create a certificate using this procedure: https://docs.microsoft.com/en-us/powershell/exchange/app-only-auth-powershell-v2?view=exchange-ps#st...
    • Make sure to remember the password you chose, or use the one in the example.
    • The exported certificates can be found in the Windows\System32 folder
  • Install the private (.pfx) certificate on the local machine (scanning server), and select the personal store. Afterwards, copy & paste the certificate into the trusted root authority as well.
  • Upload the public (.cer) certificate to your azure portal, under the Certificates & Secrets section for the app that you configured to scan O365V2.
  • Update the certificate thumbprint in your O365v2 scanning credential.
  • Rescan your O365 environment.
Do keep in mind that your security procedures and best practices may involve only using CA-generated certificates.
Bruce_B
Tim_N
Hello @andejo55
This certificate should be a public certificate and not a locally created one. Therefore, the cert will come from your public cert authority. Give that a shot and see if that helps.
Tim N.
