You can do so with the on-prem Lansweeper deployment packages.
I have not used it in a while, but this is what you have to do.
1. Download the .msu file from Microsoft for the required patch
2. Create a deployment. I can't upload the .xml that I exported, so I show the code for my deployment that we used.
<Package>
<Name>Win 10 Install KB4474419</Name>
<Description>Install Microsoft kb4474419 for Windows 10 machines</Description>
<MaxDuration>7200</MaxDuration>
<Rescan>True</Rescan>
<RunMode>-1</RunMode>
<Steps>
<Step>
<Nr>1</Nr>
<Name>Verify Windows 10</Name>
<Type>5</Type>
<ReturnCodes></ReturnCodes>
<Success>-1</Success>
<Failure>-3</Failure>
<Path></Path>
<Parameters></Parameters>
<MSIName></MSIName>
<MSIVersion></MSIVersion>
<Command></Command>
<EditMode>False</EditMode>
<Conditions>
<Condition>
<Type>4</Type>
<SpecOne></SpecOne>
<SpecTwo></SpecTwo>
<Operator></Operator>
<Value>Win 10</Value>
</Condition>
</Conditions>
</Step>
<Step>
<Nr>2</Nr>
<Name>Check 32bit System</Name>
<Type>5</Type>
<Success>3</Success>
<Failure>5</Failure>
<Path></Path>
<MSIName></MSIName>
<Command></Command>
<Conditions>
<Condition>
<Type>3</Type>
<SpecOne></SpecOne>
<SpecTwo></SpecTwo>
<Operator>5</Operator>
<Value></Value>
</Condition>
</Conditions>
</Step>
<Step>
<Nr>3</Nr>
<Name>Verify 32bit file exists</Name>
<Type>5</Type>
<Success>4</Success>
<Path></Path>
<MSIName></MSIName>
<Command></Command>
<Conditions>
<Condition>
<Type>1</Type>
<SpecOne>{packageshare}\installers\MicrosoftUpdates\KB4474419</SpecOne>
<SpecTwo>windows6.1-kb4474419-v3-x86_0f687d50402790f340087c576886501b3223bec6.msu</SpecTwo>
<Operator>1</Operator>
<Value></Value>
</Condition>
</Conditions>
</Step>
<Step>
<Nr>4</Nr>
<Name>Install 32bit KB4012606</Name>
<Type>2</Type>
<Success>-2</Success>
<Path></Path>
<MSIName></MSIName>
<Command>wusa.exe "{PackageShare}\Installers\MicrosoftUpdates\KB4474419\windows6.1-kb4474419-v3-x86_0f687d50402790f340087c576886501b3223bec6.msu" \quite</Command>
<Conditions />
</Step>
<Step>
<Nr>5</Nr>
<Name>Check 64bit System</Name>
<Type>5</Type>
<Success>6</Success>
<Path></Path>
<MSIName></MSIName>
<Command></Command>
<Conditions>
<Condition>
<Type>3</Type>
<SpecOne></SpecOne>
<SpecTwo></SpecTwo>
<Operator>6</Operator>
<Value></Value>
</Condition>
</Conditions>
</Step>
<Step>
<Nr>6</Nr>
<Name>Check 64bit file exists</Name>
<Type>5</Type>
<Success>7</Success>
<Path></Path>
<MSIName></MSIName>
<Command></Command>
<Conditions>
<Condition>
<Type>1</Type>
<SpecOne>{packageshare}\installers\MicrosoftUpdates\KB4474419\64bit\</SpecOne>
<SpecTwo>windows6.1-kb4474419-v3-x64_b5614c6cea5cb4e198717789633dca16308ef79c.msu</SpecTwo>
<Value></Value>
</Condition>
</Conditions>
</Step>
<Step>
<Nr>7</Nr>
<Name>Install 64bit KB4012606</Name>
<Type>2</Type>
<Path></Path>
<MSIName></MSIName>
<Command>wusa.exe "{PackageShare}\Installers\MicrosoftUpdates\KB4012606\64bit\windows6.1-kb4474419-v3-x64_b5614c6cea5cb4e198717789633dca16308ef79c.msu" \quite</Command>
<Conditions />
</Step>
</Steps>
<SoftwareVersion>10.4.4.4</SoftwareVersion>
</Package>
Hope this helps answer your question.
I highly recommend testing it on a test system. Update the file verification checks, and install commands to match your needs. I've not used this deployment in over a year.
