LsPush scans can't be used as trigger for deployments. In general,
LsPush is designed to be used if you have issues with firewalls or you can't provide scanning credentials with administrator access on scanned computers. These circumstances make remote deployment impossible. Lansweeper needs to be able to contact remote registry service and task scheduler on target computers for deployment.
If you would like to use an executable on network computers to trigger a scan and a deployment, you could use
LsClient.exe (which we normally don't recommend as other agentless scanning methods like
Active scanning or
IP range scanning are much more flexible).
The deployment target ("Deploy On") can either be an asset group (static or dynamic), a report (all assets currently listed by a specific custom report) or a manual selection of assets. Lansweeper will deploy the packages to the computers listed. The "After scanning" schedule would initiate a deployment on one computer which is listed in the target computer after it has been scanned. It doesn't deploy to all assets of the group, only to the computer which was scanned. Details on how to set up deployment schedules can be found in
this KB article.
