‎03-30-2017 09:59 PM
‎04-12-2017 01:55 PM
‎04-12-2017 02:00 PM
MakeBug wrote:
Where do you want this message to appear? On the client you're deploying on or on your deployment server?
You can show a message on the deploying client by creating a cmd-step with the command like msg * Hello World
However this will only work if you're deploying with the current logged in user. If you're using the system account or the scanning credentials to run the deployment the message will not show up on the screen (the command is running, but the message box doesn't show).
I myself am thinking about going a different way by creating a textfile with the current step on the tempfolder. That way I can always check the tempfolder of the computers with running deployments and can see the current state.
Afaik there's currently no built-in way to get this information.
For sure I am open for better solutions if anyone has an idea. My way feels really...ugly.
