AshleyWaterman
Hi All,
I'm trying to set deployment up within lansweeper for several programs however when I put the path to install from, it fails.
The share credentials have access to the path where the program is stored.
Example: \\desktop1\Apps\Caffeine\Caffe1ne.exe (program I'm wanting to install)
Deployment>Packages>New Package>Installer
Step one - Install File - {PackageShare}\\\desktop1\Apps\Caffeine\Caffe1ne.exe
Any ideas on what I'm doing wrong?
sullivane
Matt is correct, if you use {packageshare}, Lansweeper will replace that with what is listed in Deployment > Security Options > Default Package Share
moore_mat
Hi Ashley
If I read it correctly; the server you're running the share from is called desktop1? If so; then is the share you put in the first line accessible by your clients?
If that's the case; then you need to change the line in the deployment to match this. The {packageshare} string is replaced by the location of your LANSweeper share; so in this instance, you could probably remove it from the line to read
Hope that helps
Mat
